04-03-2024 09:17 AM
Our network management platform is sending alerts for Cisco Memory Pools (CiscoMem-reserved; CiscoMem-image; Cisco_MemoryPools_SNMP-reserved; Cisco_MemoryPools_SNMP-image) all showing as 0.0 Percent Free for some ASR 9001 and NCS 540 devices. When we log in, there does not appear to be any issues with lack of memory overall. I'm unable to find anything related specifically to the MemoryPools. On the ASR9K, the mibs for the memory pools are there, but they don't appear to be on the NCS. Looking for a way to verify if these devices are experiencing issues the the memory pools or if we should just disabled these datapoints in our management platform.
04-03-2024 09:58 AM
- This could be due to bugs in the network management platform too. To verify use snmpget (manually) to check the MIB variables used by the NMS (e.g.)
M.
04-03-2024 12:02 PM
I think on the ASR, you can use the commands:
show memory summary
show processes memory
show memory critical
to view memory usage and status.
