Cisco MIBs
sam_manay
Hi All,
Anyone knows how to get MIBs/OIDs for the following Cisco switches 6513,6509,3560E and 2960.
Thank in advanced.
sams
Joe Clarke
Go to http://www.cisco.com/go/mibs, and use the MIB Locator to determine which MIBs are supported in your versions of IOS.  From that same interface you will be able to download those MIB files.
I came to that link last time, but i didn't help me. My diffulty was not easy to determine the current IOS version for those switches.
Any other advise?
thanks for your input.
sam
Just run "show version" on the device.  The IOS version and feature set will be seen on the first line of the output.  For example:
IOS (tm) c6sup2_rp Software (c6sup2_rp-JO3SV-M), Version 12.1(23)E4, RELEASE SOFTWARE (fc1)
This switch is running 12.1(23)E4 with the jo3sv feature set (ENTERPRISE/FW W/VIP).
