Cisco Modeling Lab Enterprise help
Good morning, I have a question, why when I select CML Enterprise, only the devices that are in the personal CML are displayed, for example if I want to virtualize iOS XR it is not found in the catalog.
5 Replies 5
Mark Elsen
  - @josegarridorivas     You could also post the  question in : https://learningnetwork.cisco.com/s/topic/0TO3i00000094ZjGAI/cisco-modeling-labs-personal-community
  M.
Are you referring to a local instance running this or a sandbox?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Im using sandbox free enterprise
If you mean the devent cml sandbox, I think they removed the XR nodes some time ago, due to sizing.
Martin L
this looks like a free CML version, is it?  go to CLN CML forum to figure out ur issue;
or, if this is online CML via Sandbox, it did not  loaded properly or personal CML loaded
or, u did not attach ur images disk during install on ur PC at home
Regards, ML
**Have fun labbing!!!***
***Please Rate All Helpful Responses ***
