Cisco NCS 540 mpls problem and web access
We recently acquired a Cisco NCS 540 router and are currently facing some challenges with MPLS testing. Despite our efforts, we are unable to access the necessary MPLS commands on the device. This leads us to believe that the required features might not be enabled by default
Our goal is to enable the MPLS features for testing purposes
Has anyone encountered a similar situation or can provide guidance on how to enable the eval license for MPLS testing on the NCS 540? Any insights, step-by-step instructions, or relevant experiences would be greatly appreciated
and another question is how to enable web UI access for NCS 540 .
Harold Ritter
Hi @AmirHosseinKamrani ,
You need to install the packages you need.
Please refer to the following documentation:
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/system-setup/77x/b-system-setup-cg-77x-ncs540/understanding-software-modularity-and-installation.html
I should say that My NCS has UNIVERSAL License reservation enabled .
Harold Ritter
check the output of the command marked in bold, it should look something like this:
Router# show install active | i mpls
xr-mpls 7.0.1.141Iv1.0.0-1
xr-mpls-oam 7.0.1.141Iv1.0.0-1
xr-mpls-oam-client 7.0.1.141Iv1.0.0-1
xr-mpls-static 7.0.1.141Iv1.0.0-1
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/mpls/76x/b-mpls-cg-76x-ncs540/b-mpls-cg-70x-ncs540_chapter_00.html#concept_72E9FC3F51A14970AF313ED2504F23A1
