Cisco network Assistant Catalyst C1000
Salutations,
I am migrating my Cisco Catalyst 2950s with the Catalyst 1000s. I have added the new Devices to the CNA Community, but the tool does not recognize them. Do you have a solution on this? Thank you
3 Accepted Solutions
Mark Elsen
        - CNA is old and will not support these models , you will need at least Cisco Prime.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks marce1000, in addition to Cisco Prime, what software do you recommend to manage, monitor, configure the catalyst C1000 and C9200 switches? I have about 200 Catalyst C2950 and C2960 Switches and have always managed them with Cisco Network Assistant and Cisco Active Advisor. Do you have some advice? Thank you
                             >...and have always managed them with Cisco Network Assistant
 - As stated you will have no other option then to start using Cisco Prime, if you want to incorporate the latest generation of cisco switches too.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
 M.
       Beauty and terror
      Just keep going
       No feeling is final
