Cisco Network Assistant Problem with CORE 4506
mhuaynate
Hi friend,
I have a problem with cisco network assistant to manager a WS-C4506 which has a cat4500-ipbasek9-mz.122-54.SG1.bin IOS version. The cna dont find this device.
Thank.
Marco.
tamyotte
Does ANYONE at Cisco or anywhere else know why Cisco Netwok Assistant won't work with the 4506?
Both the Catalyst 4506 and 4506-E are supported by CNA. You need to verify reachability from the CNA host and that the target Catalyst has the http (or https) server active. With that, it should work fine.
