Cisco Network Assistant, unable to add a switch
adam.foster
I have a network running some 20 switches, two controllers and many AP's.  All the devices that should be able to connect to cisco network assistant can successfully.  However there is one switch that will show in neighbours but will give the message of “unable to connect to device” when I try and add it to the topology.
As far as I can see the config is identically to all other similar switches in the network.  I can telnet from a switch (management VLAN) to the switch in question.  However when I try to ping or telnet from the PC running network assistant (different subnet) I am unsuccessful.  However I can ping/telnet to all other cisco device from this PC.
The switch is a WS-C3560-48TS and I have included the config for firstly the switch in question and another switch of the same model and config that works correctly.  Any help would be greatly appreciated, thank you.
sho run
Building configuration...
Current configuration : 7363 bytes
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname wc3_switch_1
enable secret 5 $1$Fn0U$2rG6DadA8JSUzQzSNmMc4/
enable password 7 1511021F0725
username dis privilege 15 secret 5 $1$b3d.$S43CM1xtXyEtO5Rsil6Bn1
username admin privilege 15 password 7 0811185C224C543341
no aaa new-model
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
description ### Connected to Parkside-AP05 ###
switchport mode trunk
spanning-tree portfast
interface FastEthernet0/2
description ### Connected to Parkside-AP06 ###
interface FastEthernet0/3
description ### Connected to Parkside-AP07 ###
interface FastEthernet0/4
description ### Connected to Parkside-AP08 ###
interface FastEthernet0/5
description ### Connected to Parkside-AP12 ###
interface FastEthernet0/6
description ### Connected to Parkside-AP13 ###
interface FastEthernet0/7
description ### Connected to Parkside-AP20 ###
interface FastEthernet0/8
description ### Connected to Parkside-AP21 ###
interface FastEthernet0/9
description *** Curric4 VLAN Port ***
switchport access vlan 6
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
description ### Connected to Parkside-AP36 ###
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
description *** Connected to WC2A_Core_Switch ***
interface GigabitEthernet0/2
description *** Connected to wc3_switch_2 ***
interface GigabitEthernet0/3
shutdown
interface GigabitEthernet0/4
shutdown
interface Vlan1
ip address 10.0.0.31 255.255.255.0
ip default-gateway 10.0.0.254
ip classless
ip http server
control-plane
line con 0
password 7 144711185D07
logging synchronous
login local
line vty 0 4
logging synchronous
login local
line vty 5 15
password 7 094F471A1A0A
no login
end
wc3_switch_2#sho run
Current configuration : 7239 bytes
version 12.2
no service pad
hostname wc3_switch_2
enable secret 5 $1$Sfoj$a6AdO7PI0bP8ERhpWl3OP.
username dis privilege 15 secret 5 $1$D9c6$16yFzETOxBNHiPdTEqkxQ1
username admin privilege 15 password 7 133543002059550E78
no aaa new-model
ip subnet-zero
no ip domain-lookup
no file verify auto
description ### Connected to Parkside-AP24 ###
description ### Connected to Parkside-AP27 ###
description ### Connected to Parkside-AP28 ###
description ### Connected to Parkside-AP30 ###
description ### Connected to Parkside-AP31 ###
description ### Connected to Parkside-AP32 ###
description ### Connected to Parkside-AP33 ###
description *** Connected to wc3_switch_1 ***
description *** Connected to wc3_switch_3 ***
shutdown
shutdown
interface Vlan1
ip address 10.0.0.32 255.255.255.0
ip classless
ip http server
control-plane
line con 0
password 7 135514015A0F
logging synchronous
login local
line vty 0 4
logging synchronous
login local
line vty 5 15
no login
end
Marvin Rhoads
The switch configurations look pretty straightforward and mostly correct.
I notice that the problem switch has "ip routing" global command. Why is that necessary? You are only using it as a L2 switch, yes?  If you use "ip routing" and have no routing process (ospf, eigrp, etc.) running you would need to add a static default route (ip route 0.0.0.0 etc.) and not use the "ip default-gateway" command. Otherwise the switch itself (the SVI) does not know how to leave the management VLAN routing-wise since it is the only L3 interface defined.
(I might also add "ip http authentication local" on each and I'd definitely disable telnet in favor of ssh)
Marvin Rhoads
Worked a treat, thank you.
