Cisco Nexus 7000 netflow - missing data
chunsingkerk
I've configured N7K to export layer 2 flows. Using 2 different flow collectors (open source and commercial), gaps/drops in the reported traffic are observed on a periodic basis.
Problem doesn't seems to be with the exporters, hence I wondering if netflow configuration on N7K can be tweaked to address this symptom.
Using the 'show exporter' command, no errors/drops are observed.
Here is my configuration:
flow record L2-Custom-Flow-Record
  match datalink mac source-address
  match datalink mac destination-address
  match datalink ethertype
  collect counter bytes
  collect counter packets
flow monitor TEST
  exporter FlOW-COLLECTOR
  exporter PLIXER
interface Ethernetx/y
  mac packet-classify
  layer2-switched flow monitor TEST input
  no shutdown
switch: sh flow timeout
Flow timeout values
    Active timeout:           60 seconds
    Inactive timeout:         15 seconds
    Fast timeout:             Disabled
    Session aging timeout:    Disabled
    Aggressive aging timeout: Disabled
I'm using NX-OS 5.0(5)
Anybody know what's wrong?
Kerk Chun Sing
ameya_oke
Hi Kerk,
After exactly 30 minutes the drop occurs, I believe some process triggers on Monitoring tool which is causing this.
Did you try plotting the graph on some other monitoring tool?
It need not be a Nexus issue.
Check for logs on Nexus and on monitoring tool as well.
Are you getting the same kind of trend with graphs for other devices?
Warm Regards
Ameya Oke
Hi Ameya,
Yes, I've exported and graph on 2 different monitoring tools. It is shown in the white (pmacct/cacti) and black (Plixer Scrutinizer) background graphs. The Plixer folks couldn't figure out what could be the problem as well.
Kerk Chun Sing
I only have flexible netflow running on nx-os at L3 but looking at the doc theres a bit more required for L2 flows
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_nx_os_cg/sm_15netflow.html
Configuring Layer 2 NetFlow
You can define Layer 2 keys in flexible NetFlow records that you can use to capture flows in Layer 2 interfaces. The Layer 2 keys are as follows:
•Source and destination MAC addresses
•Source VLAN ID
•EtherType from the Ethernet frame
You can apply Layer 2 NetFlow to the following interfaces for the ingress direction:
•Switch ports in access mode
•Switch ports in trunk mode
•Layer 2 port channels.
