Cisco NTP authentication
ramonccna
Hello All
       We would like to implement NTP authentication. Do you know were can I find the devices models that support the protocol?
Thank you
luis_cordova
Hi @ramonccna ,
I think that more than looking for a specific model, you should look for the IOS version that supports NTP authentication.
Therefore, I suggest you look for a device that fits your network requirements and check that his IOS supports NTP
balaji.bandi
Since you have not asked specific to device or IOS version you looking to deploy
in general this will give you some information to start with, and any hurdle please provide more information, we can tweak and help you.
https://blog.ine.com/2007/12/28/how-does-ntp-authentication-work
BB
