Cisco Packet Tracer - problem with routing
Hi, I have a problem with this network simulation on Cisco Packet Tracer.
I have the routers connected to each other with point to point connections to which I assign the IPs starting from the address 192.168.24.80/30.
The problem is connecting the LANs to other LANs. Having clearly set the gateway, it is a LAN network whose addressing plan is based on 192.168.24.0/24 to be subnetted with vlsm with /28 for Lan and /30 for router.
I can't figure out the problem, I set the rip on each router but the PC can't exit the set gateway. However, the routers ping each other, from any router I can ping all the others, but if I ping the gateway set on each router I don't send packets. I've been messing around with it for many days and I can't stand it anymore.
2 Accepted Solutions
Blue_Bird
Hello gaetanovirgillito,
Check with rip configuration...Since you are using subnets you should use Version 2 and no auto-summary commands in both routers....
Here is the sample configuration:
R1(config)# router rip
R1(config-router)# version 2
R1(config-router)# network x.x.x.x
R1(config-router)# netwrok x.x.x.x
R1(config-router)# no auto-summary
Best regards
******* If This Helps, Please Rate *******
M02@rt37
Hello @gaetanovirgillito
Please add this on each router:
PCs should ping each other:
Best regards
Blue_Bird
Best regards
M02@rt37
Best regards
I love you!! I'll marry you ahaahahha...
Thank you very much I've been fighting with it for 5 days
You're very welcome @gaetanovirgillito
Best regards
