cisco pi 2.2 cpu monitoring dont work on som switch (3650 4948)
david_nyring
hey
i can't see any cpu utilization and memory utilization   on my WS-C4948-10GE and  WS-C3650-24TD, both is completed in last inventory collection status
we have WS-C3650-48PS that is working perfect with cpu monitoring and ram
when i go in the device to system -> memory pool i can see processor memory so thats why i think thats it is only a cpu reading problem, but when cpu reading fail i just also dont show memory utilization
ios version
WS-C3650-48PS      03.03.05SE
WS-C3650-24TD      03.03.03SE
WS-C4948-10GE      15.0(2)SG8
i have PI 2.2 with patch 2.2.1 and device packet 2
can some on confirm if pi is using snmp oid  1.3.6.1.4.1.9.9.109.1.1.1.1.8 (cpmCPUTotalEntry) to read cpu ?
or even better a solution/ider why it dont work :D
regard
David
Scott Plank
Since the CPU monitoring on the 48-port 3650 is working, and the 24-port 3650 is not - have you tried upgrading the 24-port to the same code level as the 48-port? That would probably be the first thing I would do, just to eliminate mismatched IOS XE versions as a potential variable.
I'm afraid I can't offer a suggestion on the 4948, other than to say that there is a slightly newer maintenance release - 15.0(2)SG9 available for it. You might double-check your SNMP config, and make sure the view that you have configured on the device is not preventing CPU polling.
i also relly like to try updating the the WS-C3650-24TD but when i just have a hunch that maybe this is cause of the issue i will not be a loved to upgrade the ios on this switch until some on can say it will help it out, sadly but that the company policy on that point :)
the 4948 i can duo with what please me its just a test switch but sadly its seems that it is 2 difference issue with the monitoring of the cpu :(
Ashok Kumar
Try Deploy/Undeploy the Device - Health (default) template, but it doesn’t solve our problem.
Device - Health (default) -Deploy/Undeploy
[1] Go to Deploy > Configuration Deployment > Monitoring Deployment > My Templates > Device - Health (default)
[2] Click on Undeploy & deploy
- Ashok
Please rate the useful post or mark as correct answer as it will help others looking for similar information
thx this help on the WS-C4948-10GE to work perfectly now.
i sad to say that i dindt have the same effect on my WS-C3650-24TD now it show the memory utilization grahp perfect, but it still the same story about cpu utilization.
WS-C3650-24TD is in a stack i dont know if that have any effect on this switch, because when i run thecpmCPUTotalEntry oid it return 2 cpu when on the 3750 stack it only return 1
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.8.1000 = Gauge32: 6
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.8.2000 = Gauge32: 1
so 3/4 solve so faar :)
