Cisco PI 3.1 WLC & Client Statistics issue.
AK002
Hi All,
Can any one help on the below issue in PI 3.1
 Cisco Prime Version 3.1. We have noted that the graphs stop presenting information, when you add and then re add wireless LAN controller the statistics then begin to populate again but over time they stop. We have had this occur a few times and have re added to Prime but I would assume this isn’t expected behaviour.
Regards, AK
Mark Elsen
 - Is there a need for  a continious re-adding of the controller.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
No,
We are adding because the statistics are not showing. After adding its showing.
Arun
  - Ok,possibly try PI 3.1.6 if not already installed , and or with latest update ; testing with PI3.2 is also an alternative but would require more time (indeed)
M.
       Beauty and terror
      Just keep going
       No feeling is final
Currently using 3.1.0 version..
Whether the below cavetes helps in 3.1.6 to solve this issue.
CSCvd71172 TransientObjectException logged for WirelessControllers
AK
