Hi all,
I have some questions about Cisco Prime i hope you can help me.
1. Is it possible to create some customized object based on 3 specific pollings or based in ipsla?
Example: Imagine we have 500 routers, and i want to monitoring 3 link's in each router. If the 3 link status are ok, my object will be green, 1 or 2 of them are down my object will turn orange, if 3 are down my object will be red.
2. Is the generic dashlet limited to a total of 100 results?
