Cisco PI2.0 -- Configfiles no longer in filesystem
lo.mueller
Hi all,
upgrading from LMS 4.2x to PI 2.0 I spent a lot of time searching the filesystem
for path to config files (/var/adm/CSCOpx/files/archive) but unfortunately was unable
to find them.
Does anybody know in which location these config files are stored?
Maybe in the oracle-DB.
How can these files be extraced for further processing if they are in DB?
Thanks for any feedback
Lothar
AFROJ AHMAD
Hi Lothar,
check the below link , hopefully ,it will answer your query ..
https://supportforums.cisco.com/message/3975460#3975460
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Lothar,
Thanks-
Afroz
Hi Afroz,
thanks for linking to the discussion already on the run.
Best Regards
