Cisco Prime 1.3 applications dashboard not visible
holzhirt1
Dear all, I have added a flow exporter from 2 wlc 5508 in direction of our Cisco Prime, under system / data sources i see data from my controllers coming but status is down. Addtionally I cannot see under details dashboards the applications dashboard. even if i try to manage dashboards i cannot have applications. After checking our license with our reseller he said that we should have this netflow feature, But could you explain me why i cannot see the dashboards ? Do we need to install or configure a module ? Thanks
AFROJ AHMAD
Hi ,
AFAIK , you need to have "assurance licenses " for this.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks-
Afroz
Thanks that was what was missing, will purchase L-PI2X-AS-25 to start...
