Cisco Prime 2.0 Classic Theme vs Lifecycle Theme view
doug.moffat
Is the Livecycle Theme being retired?
This is a 2 part question.
  1. In a course I just finished, it was mentioned that in the next release of CPI, the Lifecycle Theme view was being removed.
    Is this correct?
  2. Based on the comments from the course instructure, I did a comparison of the two themes.
    What I discovered is that, in the Classic Theme view, I am unable to see any of the routers that I've created via the Lifecycle Theme.
    I am, however, able to view the routers in reports that I created in the Classic Theme.  The data is there, it's just not being displayed.
    Are there plans to correct this, or am I missing something?
Doug Moffat
Senior Operations Engineer
Sunlife of Canada
AFROJ AHMAD
Hi Doug,
From PI 2.2 onwards , Classic theme will be deprecated NOT  the LifeCycle theme.
Check the attached screen shot.
Hopefully you will see all the options under LifeCycle theme from 2.2 onwards
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks Afroz...  This is good news.
Doug Moffat
Sunlife of Canada
Adding to Afroz's reply - in 2.2+ the theme is known as "Converged" (or at least that's what the current name for it is).
