CWLMS-4.0 vSphere Client 5.0.0
Mike Wegner
Good morning
I have a problem with my CWLMS-4.0 in combination with the vSphere Client 5.0.0.
In the overview a server is shown as Windows 2008 Server but it is a Red Hat Linux.
This issue produced some problems.... How is it possible to change it to Red Hat Linux?
Many greets
Mike
Vinod Arya
LMS 4.0 is not supported on ESXi 5.0 and is itself obsolete. You should move to LMS 4.2 where it is supported.
Also, to explain the problem in more detail, do you have any screenshot? Where do you see Server platform difference? In LMS or vSphere?
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hello Vinod
The difference is Cisco Prime LMS. As you can see in the screen the device is shown as Windows 2008 Server. In Cisco Prime Infrastructure it is correct implemented as Red Hat Linux.
Its also the current Version of LMS running with 4.2.5
Attached you will find the screens of the effected device.
Thanks in advance
Mike
