Cisco prime 2.1 not showing wired clients connected to Cisco 3850 switches
Hello All,
I have around 80 Cisco 3850 switches at a customer network and they are using prime infrastructure 2.1.2 to manage these devices. Most of the features are working fine except that the prime does not show the wired clients connected to the switches. The wireless clients are shown properly but not the wired clients. Their core switches are nexus 7k. The SNMP configuration on the switches is as follows.
snmp-server group xxxx  v3 priv write xxxx-VIEW-WR
snmp-server view xxx-VIEW-WR mib-2 included
snmp-server trap-source Vlan100
snmp-server host x.x.x.x version 3 priv testuser
Please help me to resolve this issue.
Shabeeb
7 Replies 7
Marvin Rhoads
I believe you need to use the netadmin SNMP RO credential set to properly collect end host data on the Nexus platforms.
I managed to get the end hosts connected in 3850 switches with the use of snmp context command. But now the issue is that prime is showing only the mac address of the device , not the IP address.
Is there anyway to resolve this issue?
Dis you try using the netadmin SNMP user credential on the Nexus?
No.. " net admin" is a user role in the nexus right??.. I have to assign that user role to the  snmp user I guess..
I assigned the user to the system defined role "vdc-admin". But still the same
Do you have multiple VDCs?
If so, each needs to be managed directly (i.e., essentially as separate devices) by Prime Infrastructure.
Sougata Roy
I have the same problem. Did you get any solutions for it?
