Cisco SG300-28 switch blinking system light
daniel.gemmill
I have a Cisco SG300-28 switch and upgraded the boot to the latest version 1.3.5.06 but after a reboot the system light keeps blinking.
I updated the firmware through several hops to version 1.4.76 (Active) but still the blinking summary light remains.
I can still access the switch and it seems to be operating normally in my small test environment but would like to remedy the system light.
Any thoughts would be appreciated.
Mark Malone
Are you on the default address as that's expected looking through the doc
When the switch is using the factory default IP address, the System LED
flashes continuously
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
Mark Malone
daniel.gemmill
Ugh.  Yes, I was on the default and as soon as I changed the IP address the System LED stopped blinking.  I was sure it wasn't blinking before I started the upgrades but I was incorrect.
Appreciate the help!
