Cisco Prime 2.1
thusharadennis
Dear Experts,
Kindly confirm is it possible to take the configuration back of a particular devices and get the output of the any cisco device(router/Switch) from Cisco Prme 2.1
Reagrds
TD
Marvin Rhoads
Do you mean create configuration backups?
If so, that's supported for the devices listed on the Compatibility page for PI.
I'm not sure what you mean about output.
Hi Marvin,
Thanks for the support..
I need to take the configuration back of the device.. that Output i meant in the above query
TD
