cisco prime 3.2 job issue
dar.jor76
hey all,
we are running Cisco prime 3.2 and we have a weird issue. no scheduled job is currently working and when we try to start on of them manually by using now option it says that job has running successfully but no progress happens ( status , last running ... etc stays the same as old ).
then we though about reloading vm and we did it , after reloading when we chose a job and run it now it works but after that job problem return again and the same job will not work again , also we have found that if we define new remote ftp repository and attach it to server job it works for the first time then problem appear again
0 Replies 0
