Cisco Prime 3.8 registration failed due to connection error
oktayakan26
After installation, we encountered below error. "Registration failed due to connection error"
10 Replies 10
check if you might need to install the security patch described in the link below. There was a user recently who had this problem as well, and installing the latest security patches resolved this...
https://www.cisco.com/c/en/us/support/docs/field-notices/721/fn72110.html
Are you trying to license the Cisco Prime in smart Account?
Mark Elsen
          - FYI : https://www.cisco.com/c/en/us/support/docs/field-notices/721/fn72110.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Netzwerker
I have the same problem with Cisco Prime 3.5!!
Did you found a solution?
        >....Did you found a solution?
         Did you (also) read replies ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Yes I'm using Prime 3.5 not 3.8 and 3.9 which are affected and mentionned in the document!
- Your Prime version is older, so it is affected too. They didn't bother to
include too old versions. You will need to start thinking about an upgrade
path....M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank sir for your reply but our ESXI version is 5.5 so it's supported just by PI3.5 or earlier ! In our case, an upgrade can't be a solution!
- I am afraid then you are dead locked. If this is business dependend then
you need to involve Cisco TAC. M.
       Beauty and terror
      Just keep going
       No feeling is final
