05-17-2013 12:28 AM
we are upgrading LMS from 3.2 (windows) to LMS 4.2 and VMWare. But now i recogniced that it only runs with ESX 5.0.
We only have version 5.1 so does anyone have experience if its running with 5.1 ?
Is there any plan from cisco for an official version supporting ESX 5.1 ?
Norbert
05-17-2013 12:43 AM
Hi Norbert,
I successfully deployed Prime Infrastructure 1.3 on ESX 5.1, no problems at all.
Sebastian
05-17-2013 08:46 PM
You will not face any problem in upgarding LMS 4.2 on ESXI 5.0. It will work fine. For more information you can go to below link.
05-18-2013 07:09 AM
The two answers above address different aspects than the OP's question.
Cisco Prime LMS 4.2 is not currently supported on ESXi 5.1. While you may be able to get it to work (I haven't tried personally), if you run into any issues you will not be in a supported configuration so official Cisco support may fall short of what you could otherwise enjoy.
05-18-2013 02:20 PM
Hello Norbert,
I've once installed LMS 4.2 on ESXi 5.0 and 5.1 for a test enviroment. Installation and running the application works, but the LMS Software is so slow, that when you click on a menuentrie you have to wait up do 45 second until anything happens.
As Sebastian said, PI 1.x works fine on ESXi 5.0 and 5.1. We're running several PI 1.3 Installations on ESXi 5.1. Installation and running the application works perfect. For installation I've used the .ova files which can be received at the Cisco Download area.
But if you ask me, if you want to install PI as a new installation you should switch to PI 2.0 which is or will be release in June, if I'm right.
If you need some installation help, feel free to contact me.
Kind regards
Kai
05-18-2013 02:31 PM
Yes PI 2.0 is due out at the end of June. It will add a lot of features missing in PI 1.x for wired network management yet still fall short of what LMS can do.
So for current CiscoWorks and Prime LMS customers, they are best served by staying current with LMS for a few more releases.
The business unit offers weekly sessions on both products that are open to the public. Monday is for LMS and Thursday is for Prime Infrastructure. I've created a document with the details to help spread the word.
