Cisco Prime Continuously logging onto one switch
rkelly100
Hi All
After looking at the tacacs authentication logs in our ACS I notice that Prime is continuously trying to log into one of our switch. We have around 1000 network devices on our LAN and this is the only switch that seems to be having this issue.
I know the account is our Prime AAA account and that it is coming from our Prime server.
Is there anyway of figuring out were on Prime this is coming from (user defined or system job or poller)?
Its like trying to find a needle in a hay stack!
Any help would be much appreciated Thanks
Richard
Cisco Prime 3.3 is our current version but problem was still present on previous versions
23 Replies 23
Mark Elsen
 - Is the device configured correctly for Prime's logon (credentials); if needed remove the device from Prime re-enter it, but issue verify credentials first, before the final add.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
When deleting it it did ask whether I wanted to delete aps associated with device so hopefully that will do the trick. I will know by tomorrow and let you know.
Richard
How continuously is this? Like every 10 minutes perhaps?
If the device is sending SYSLOG messages that 'could' indicate a config change, then PI is waiting 10 minutes and then tries to download the configs files.
If the device continues to send SYSLOG messages, PI will try again in 10 minutes.
This should be visible in the show log of the device.
There is no system job on PI that runs every 10 minutes that would do this.
I do wonder what apps you are talking about.
Hi All
The issue is still happening in fact going by the logs I can see that PI is trying to login
Below is an outline of the frequency at the minute and this will happen several times a day.
12:05,12:03,12:01,11:59,11:57,11:55,11:52,11:52,11:52,11:49,11:47,11:45,11:43,11:43,11:43
No syslog configured on the console. I do see an access point on the switch that is continuously going up and down in the logs.
Perhaps this is the reason and keeps kicking off a PI job?
Richard
                      - What exactly are the logs saying ?
>Access point going up and down.
  - Can you remove the access point from  the switch; is the prime-issue then resolved ?
M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi Marce
So on further inspection I realised the AP was juniper so shouldn't be communicating with PI. Anyway I have shut the AP down and am still seeing PI trying to log into that switch every 2 minutes.
Richard
 Ok. also check the switch model and the current software version installed ; compare this with Prime compatibility info (see link below); your OS version , for instance (on the switch) ; might be too low and may need upgrading to get compatible with prime 3.3 (e.g.)
https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
M.
       Beauty and terror
      Just keep going
       No feeling is final
Model                        SW Version       SW Image Mode
WS-C3850-48P        03.06.04.E        cat3k_caa-universalk9 INSTALL
Seems to be supported
 - Could you try to stop and re-start Prime using : ncs stop ; followed by ncs start  ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Yes tried that - no joy unfortunately
>... Prime is continuously trying to log into one of our switch
  I want to re-iterate on this; where is this seen , and what is the content or the exact value of the message you are seeing ?
M.
       Beauty and terror
      Just keep going
       No feeling is final
I assume you may have an ACS that tells you about PI making the connection to the switch?
I think it can also tell you what commands PI gives on the switch.
This may give us clue where the job is coming from.
I am seeing this on our Cisco ACS Server - Screenshot of the content attached
Can you click on the details icon?
