06-08-2015 04:17 AM
Hi Guys,
i installed prime 2.2 & found that overview page doesn't display anything, I tried to add dashlets but it didn't work. Let me know your idea.
06-08-2015 04:23 AM
Hi ,
Are you able to see devices under Inventory ? was it working before or initial setup ?
Have you tried to restart the services , if not tied it once ( ncs stop and ncs start )
you can also try to restart the server.
Thanks-
Afroz
***Ratings Encourages Contributors ****
06-08-2015 05:17 AM
It worked earlier & i already tried with restarting server/services. I can see devices under inventory.
Now it doesn't work.
06-08-2015 05:18 AM
try to reboot the server once
07-14-2015 05:51 AM
I have same problem ... inventory work fine (all devices monotoring), but lost all dashboard overview
this wil ba a bug ??
