Cisco Prime DCNM
Mukund Sandur
I am planning to use Cisco Prime DCNM 6.1(1b) to manage Nexus 7K and Nexus 5K.
Is it required to run SNMPv3 on network devices for device discovery. Is it not possible to use SNMPv2.
What are the DCNM client requirement like Windows OS, RAM etc.
Thanks in advance.
Rgds,
Mukund Sandur
Marvin Rhoads
DCNM-LAN requires device-level login credentials. Reference. Under the covers it uses netconf over SSH (RFC 4742).
The client is downloaded via browser and Java-based. It is supported with Java JRE 1.6.0_31. (Reference) Newer JRE versions may work but it's best to use the recommended one.
