Cisco Prime - extract list of hostnames and their serial numbers.
paulkilcoyne
Hi all,
is there a way of extracting a list of hostnames ( for devices in EMEA ) and their associated serial numbers from Cisco Prime and into say a csv file?
Many thanks,
Paul
AFROJ AHMAD
Hi Paul,
if you have Prime Infrastructure then  run the below report :
Report > Report Launch Pad > Device > Detailed Hardware > Detailed Hardware Report Details
If Prime LMS then :
Reports > Inventory > Detailed Device
Hope it will help
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Is it possible to extract the serial number from each module, fan, PS in a 6500 switch chassi?
