Cisco Prime Hardware
kamalmander
I want to test Cisco prime infrastructure, Will intel corei5 processor work with 1TB and 16 GB ddr3 RAM?
Kamalmander
6 Replies 6
Rob Johnson
See the system Requirements link below-
http://www.cisco.com/en/US/partner/docs/net_mgmt/prime/infrastructure/2.0/quickstart/guide/cpi_qsg.html#wp46865
I guess as long as your intel corei5 processor is capable of running ESXi versions 4.1-5.1, then you should be good:::
Hi Rob,
Thanks for the answering.
Cannot see document as don't have enough rights.
regards
Mandy
Hi kamlzeet,
r u looking for Cisco Prime infra. requirement:
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/quickstart/guide/cpi_qsg.html#wp46865
Then go to System Requirment.
Hope it helps.
Whenever you see a link with "partner" in the URL, just try substituting "customer" instead. 95% of the time the content is also customer-accessible.
Those of us whose cisco.com accounts have partner privileges are automatically directed to the pages with "partner" in the URL and don't always notice when posting links.
http://www.cisco.com/en/US/customer/docs/net_mgmt/prime/infrastructure/2.0/quickstart/guide/cpi_qsg.html#wp46865
Saurav Lodh
Level 7
Level 7
which version of PI do you want to test ?
PI 1.2
