Cisco Prime Infrastructure 1.2 with SNMPv3
Dears,
I am trying to add a router on Cisco Prime Infrastructure 1.2 using snmpv3 (authpriv, sha & aes256). When i go to device work center and add a device, i cannot find the AES-256 in the privacy options. Only None, DES, and AES-128 are available.
Is there any workarround?
Please advise.
Moustafa
Marvin Rhoads
PI only supports SNMP privacy up through AES-128 at this time. Reference the guide section on adding an new SNMP credential entry.
Additionally there is a bug with SNMP v3 support in PI 1.2. It should be resolved in PI 1.3.
Hi Marvin,
Thank you for the valuable response. Please note that when i go to discovery settings i can see the AES-256. However, when i try to add the device from device work center it does not display AES-256.
It is a weird behavior.
