Cisco Prime Infrastructure 2.1 High availability Question
Hello All,
I am configuring high availability for two prime infrastructure 2.1 servers. I have configured manual HA between the servers. I need to know what will be the configuration in the devices ( switches,routers etc.) for proper working of the HA. For example
Should we need to configure both the prime infra servers as snmp hosts in the devices??. If we have to when an event happens the switch well unnecessarily send the traps to the secondary even when the primary is alive??.
If anyone has a copy of the configuration of such a set up please share it with me.
Thanks and Regards
Shabeeb
AFROJ AHMAD
Hi Shabeeb,
You are correct on that part that unnecessarily devices will  try to send traps to the secondary server if you specify that in the device's config. I don't think it should be a concern , this is expected.
otherwise you need to configure them later once the PI server fail over to secondary .
If you have any other doubt ,kindly ask.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
