ACS 5.2
Andy Guley
I am running ACS 5.2.  I need to reboot the server through the GUI.  I can't find a place anywhere in the GUI to reboot.  Can someone please lead me to where I can reboot?
AFROJ AHMAD
AFAIK, Unfortunately , there is no way you can reload the ACS server via GUI , it has to be done via CLI  only  with reload command.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Andy Guley
I just found this:
Problem: Unable to Restart ACS Server 5.x from GUI
This section explains why you cannot restart the ACS server version 5.x from the GUI.
Solution
There is no option available to restart the ACS 5.x server from the GUI. The ACS can only be restarted from the CLI.
I guess I cant do it from GUI. When I try to sign into SSH session I get access denied.  My account is a SuperAdmin.  What do I need to do to ssh into it?
AFROJ AHMAD
Thanks-
Afroz
