01-27-2016 08:56 AM
I created several configuration templates in Cisco Prime Infrastructure 2.2 under "Features & Technologies" that Prime said were successfully created. However, they do not appear in the list, or anywhere else in PI. I then try to create it again with the same name. Prime says a template with that name already exists, but I can't find it anywhere. Does anyone know how to correct this?
02-10-2016 09:57 AM
Bill,
Were able to figure a solution out? I have the exact same issue.
Thank you!
02-10-2016 10:44 AM
Check under "My Templates".
It won't appear on the "flyout" menu but if you first go to "Configuration > Templates > Features & Technologies" and select that, you should see it as a choice on the page that results (open in new tab to zoom):
02-10-2016 01:14 PM
Thank you Marvin for your reply.
This is exactly where I look for them but I still can't find them, even when using a filter on the type or the name.
What is the version of the instalaltion your took this sceenshot from? I'm asking because I'm on 2.2. and the look of my installation is quite different even though it's recognizable.
Thank you again for your time.
02-10-2016 01:17 PM
Sorry - my screenshot is from a 3.0 installation.
They appear in the same area (just the UI looks a bit different with top of screen menu vs. side flyout) on 2.2.
I don't have a 2.2 instance handy to provide screenshot; but the ones in my 3.0 were from an upgrade of a 2.2 system.
