Cisco Prime Infrastructure 3.1 - admin password reset
yezdi
Old admin password does not work. Was trying to reset it. I can SSH in as root or admin. I can reset the password successfully. running-config file get's updated. But I cannot login through web browser.  Getting "Invalid Username or Password. Please try again".
Used the following steps for password reset. New password does follow the password policy
config t
username admin password plain mynewpass role admin
end
copy r s
Password Policy :
lower-case-required
upper-case-required
digit-required
no-username
disable-cisco-passwords
min-password-length 6
myciscopi/admin# ncs status
Health Monitor Server is running. ( [Role] Secondary [State] HA not Configured )
Database server is running
FTP Service is running
TFTP Service is running
Matlab Server is running
Matlab Server Instance 1 is running
Matlab Server Instance 2 is running
NMS Server is running.
Plug and Play Gateway is running.
SAM Daemon is running ...
DA Daemon is running ...
Let me know if I am missing any steps
TIA
  For web access, you need to use root.  Admin is for CLI.
yezdi
Get the same error with root, even though the password is correct. I have another CPI device where I login using admin without any problems.
did you try shut it down and up again?
 Or, if you create a new user, can you login?
yezdi
Doesn't allow me to create a new user. Tried different variations of "user name", same error.
myciscopi/admin(config)# username newuser password plain newpass role admin
% Error: Unable to create user, username is reserved by the system..
