Cisco Prime Infrastructure 3.1 /var full
victor.mansson
Hey
We're getting notificationsfrom our VMware about Cisco Prime Infrastructure's /var partition is full.
After logging on to shell and run df -h I get the following:
/dev/mapper/smogsvg-varvol
Size: 3.9G Available:0 Use: 100% Mounted on: /var
Can't find any information about the /var partition or how to clean it up. I've run the normal ncs cleanup without success.
Can anyone point me in the right direction?
5 Replies 5
marce1000
  - You can become root on  the prime server if logged via ssh (admin account only) and issue the shell command and afterwards 'sudo -s'.  You can find the biggest files in the /var directory , then using,for instance :
                       find /var -mount -printf '%s %p\n' | sort -nr | head -10
M.
Thansk for the information.
Found out that is was the logfiles from /var/cache/logwatch/ that was eating up the space.
Got some help from
https://supportforums.cisco.com/discussion/13194071/cisco-prime-infra-31-does-not-start
and
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvb45802
1. SSH to your Prime Infrastructure
2. Login and then typ: shell and login again
3. Run sudo su -
4. run df -h to check the diskspace
5. run cd /var/cache/logwatch/
6. run ls -l to view files
7. run rm -rf logwatch.{filename} to delete a file or logwatch.* to delete all
Vider le fichier /var/log/wtmp
ran into an issue with prime not booting.
followed advice from this thread and did the:
shell
sudo su -
Found that the largest file by far was:
/var/log/wtmp
Did the following:
cd /var/log/
rm -rf wmtmp
exit
exit
Restarted the appliance
wmtmp appears to be a swap file that must not be important since PI was able to boot up with no issues following its' removal.
