12-04-2017 03:11 AM - edited 03-01-2019 06:17 PM
Hi!
I have two standalone Cisco Prime.. i.e. Both were as primary and secondary.. but on primary server the database has been corrupted. At this moment, I have OLD Prime as secondary (active) and NEW Prime also as secondary...
My questions is: how to switch role on NEW Prime to primary, and how configure HA on both servers?
Everything using CLI
12-04-2017 03:54 AM
Hi @User24571
If you don't have those server in HA, don't make sense called them Primary and secondary. If they are in standalone mode, they will work in parallel.
You can refer to this link to understand HA and Prime:
-If I helped you somehow, please, rate it as useful.-
12-04-2017 09:54 AM
If you installed PI as a secondary, that is all that node will ever be. You will need to install a new primary. You can't make a secondary install become a primary, all it can do is assume the role of a secondary HA server.
12-04-2017 09:56 AM
If you've reinstalled the new primary machine from scratch, just point the HA configuration to use the existing secondary. Once that is done, the database will resync. Once that is complete, you can tell it to failback to the primary.
01-08-2019 07:21 PM
