Cisco Prime Infrastructure 3 Installation
aghm
My Company is going for Cisco Prime Infrastructure 3.3 (Virtual image). I am charging for ordering, Design, installation and management.
My question is:
1- What is requirement for installation? (not hardware specification)
2- Do we need SQL server at all? (If yes, Can we use shared DB?)
Daniel
Marvin Rhoads
The current version of Prime Infrastructure is 3.1. When you install the virtual appliance, you have 4 options that you can choose from during the OVA deployment on your VMware ESXi server. They are as listed here:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/quickstart/guide/cpi_qsg.html#pgfId-121836
Cisco Prime infrastructure includes all necessary database software in the package. It runs an included Oracle database instance and that choice is not optional nor is it possible to use an external or shared instance.
Marvin Rhoads
Thanks Marvin,
