Bookmark
Subscribe
998
Cisco Prime Infrastructure 3.x multi tenancy?
alig.norbert
Level 4
Level 4
Hi all,
We are looking for a network configuration management solution (IOS config changes, backup, centralized firmware upgrade e.g.).
The main goal is to handle several customers wirh overlapping networks.
Does Prime Infrastructure 3.x support multi tenancy wirhout doing fancy NAT'ings?
Or is there other tools (manageEngine, Solarwind)? No monitoring needed?
Norbert
Hi Norbert,
If you havent noticed,See here .that's for v2.2 and I believe is the same case for v 3 as well.
cheers
Prabath
***Please rate all the useful posts***
-Prabath
Hi Prabath,
I have read this one but was hoping there would be some improvement in the 3.x release.
Greets,
Norbert
