intermittent packet drop issue in lan network
UMESH LONDHE
we are facing intermittent packet drop issue in our lan network. we have three general vlan in our network as floor vise and have distribution switch per floor. at first floor we are facing the packet drop issue. while pinging to ip add in that network machine it pings but, it gets drops intermittent
ping output like.... transmit failed general failure...
after some drops we get ping response again. can anybody help me out to resolve this issue.
Mark Malone
Is it only to that machine you see drops ?
if you ping to another ip address on same switch do you see drops or just this machine ?
can you post the show interface x/x where the machine is connected
have you put a laptop on same port where machine is to see if issue is the same to rule out machine nic card being at fault
Hi mark,
as i mentioned, on distribution switch we have 15 access layer switches connected and packet drop issue is occurs randomly any   machine connected to that distribution switch now and then. as you suggested i have changed switchport, patch cord, and physical machine, also tried with loptop, but packet drops are still observed.
Here is sh int of switch port
FastEthernet0/12 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001b.53ef.548c (bia 001b.53ef.548c)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:06:32, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4071
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 9000 bits/sec, 9 packets/sec
5021375 packets input, 679471422 bytes, 0 no buffer
Received 22910 broadcasts (18461 multicasts)
0 watchdog, 18461 multicast, 0 pause input
12269463 packets output, 8168187320 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
that switchport is clean but have you checked each ports from src to dst along the path , if that port or end device was at fault there would be crc and input errors etc on it to indicate an issue
you need to confirm each port the traffic passed through , have you checked the layer 2 trunk uplinks between src -dst
Check the cpu on the dist switch as well show proc cpu sorted make sure its not overloaded when the issue is occurring , show proc cpu history
when your on the dist switch do you have any intermittent responses between devices on the same switch
