Cisco Prime Infrastructure - Assurance. Upgrade from 1.2 to 2.0
smunzani
We had purchased Prime Infrastructure 1.2 with SAU smartnet. Before we deployed 1.2 now I see 2.0 version is out and we qualify for upgrade license. However when I login to CCO to download the OVA file, I see 3 different editions. Express, Pro and Standard. Which one do I qualify to install? I have purchased following part numbers with 1.2 version.
R-PI12-K9     -     Qty 1
L-PI12-LF-100-LIC     -     Qty 1
L-PILMS42-100     -     Qty 1
L-PI12-LF-100     -     Qty 1
Thanks in advance,
Sam
Marvin Rhoads
The different OVA images simply build the ESXi guest OS with the parameters necessary to support the target size of managed networks.
For a 100 managed device license (as your PI 1.2 SKUs indicate), you will be fine with the 2.0 Express image (although can can download any one of them).
See tables 2 and 3 of the Prime Infrastructure 2.0 data sheet for specifics.
AFROJ AHMAD
Check the below link for difference between [ Express, Pro and Standard ]
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/quickstart/guide/cpi_qsg.html#wp46865
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/quickstart/guide/cpi_qsg.html#wp75315
L-PI12-LF-100-LIC and
L-PI12-LF-100   :: Prime Infrastructure 1.2 - Lifecycle - 100 Device Lic PAK
are same as per my understanding and you can use these license to installed PI 2.0 with device count of 100.
Note: you  can also add additional licenses(feature license ) for more Lifecycle (via R-PI12-K9 skus), which can be used for both Prime Infrastructure and LMS.
Thanks-
Afroz
[Do rate the post if you find it useful]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
