11-24-2020 03:35 AM
Hello:
Customer wants to know for Cisco Prime Infrastructure - Is it possible to customize the color for Alarm Severity Icons color?
The following is the default color:
Color Description Severity Icon
Red Critical Critical alarm
Orange Major Major alarm
Yellow Minor Minor alarm
Light Blue Warning Warning alarm
Green Alarm cleared;
normal, OK
Medium Blue Informational Informational alarm
Dark Blue Indeterminate Indeterminate alarm
If it is impossible, is there any formal documentation describing this?
Thanks a lot for response in advance!
Best Regards
Danny Lin
Solved! Go to Solution.
11-24-2020 06:06 PM
Thanks a lot.
11-24-2020 08:03 AM
- No , but you should be able to change the severity level for a particular alarm (class)
M.
11-24-2020 06:06 PM
Thanks a lot.
