Cisco Prime Infrastructure Report Does Not Show Up on Web Page
fdharmawan
Level 4
Level 4
Hi Guys,
I often generate reports from PI and so far got no problem exporting the report until yesterday. I wanted to generate Rogue AP report. The path is Reports > Reports > Report Launch Pad > Security > Rogue APs(Updated). When I clicked Save and Export, PI usually takes some time to generate the report and then the file will be available to download. But somehow, for my scenario, it did not work. Even though when i clicked Run only, there were some data.
So I checked into the disk by running "dir disk: recursive" and found the file on the disk.
Directory of disk:/ftp/reportsOnDemand/RogueAPsUpdated
43051 Feb 14 2019 16:07:43 Rogue_AP_20190214_160743_011.csv
45116 Feb 14 2019 16:10:19 Rogue_AP_20190214_161019_689.csv
Is this some kind of bug? Well, it's kind of annoying when you have to transfer the file using FTP when it is usually not. Any suggestion?
Thanks.
0 Replies 0
