Cisco Prime Infrastructure upgrade from 3.3 to 3.7 fails
sejelmohajj
primeInfra/admin# application upgrade PI-Upgrade-31x_32x_33x_34x_to_3.7.0.0.159.tar.gz defaultRepo
Save the current ADE-OS running configuration? (yes/no) [yes] ?
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Please ensure you have a backup of the system before proceeding.
Proceed with the application upgrade ? (yes/no) [yes] ?
DO NOT press ^C while the upgrade is in progress
Aborting upgrade with a ^C may leave the system in a unrecoverable state
Initiating Application Upgrade...
Stage 1 of 7: Transferring file ...
-- complete.
Stage 2 of 7: Unpacking file ...
-- complete.
Stage 3 of 7: Executing pre-install ...
ERROR : Please run the application upgrade from the system console to
monitor upgrade progress. Use system monitor, serial terminal or a virtual console
to initiate the upgrade.
WARNING : It is strongly recommended to copy the latest backups to an
external repository before proceeding with the upgrade.
% Pre-install step failed. Please check the logs for more details.
primeInfra/admin#
primeInfra/admin#
Marvin Rhoads
It will fail if you try to upgrade from an ssh session. The message tells you:
If you have a VM, use the ESXi console. If it's a physical appliance use the local keyboard and monitor (or CIMC).
Marvin Rhoads
