Cisco Prime Infrastruture - old system jobs
A_1
I am facing an issue with Cisco Prime Infrastructure.
As you can see on the attached screenshot, I have 67 old failed system jobs from more than two year old that can't be cleared/deleted.
Those jobs are in status "complete" but their last run status is "failure".
I tried to pause a job ("pause series"), but i get the error : "Unable to pause the job."
I tried to resume a job ("resume series"), but i get the error : "Job PnP Status PollingWed Mar 15 14:17:39 CET 2017 is in Completed state, hence cannot be resumed. Only suspended jobs can be resumed."
I tried to re-run them but nothing happen.
It seems that I can't edit or delete those jobs.
I can see their job IDs but so far, i didn't find how to kill those jobs using the cli and job ID.
Do you know how I can clear/delete those old jobs ?
I run Cisco Prime Infrastructure 3.5.0.0.550 on Red Hat 7.5
Thanks in advance
gpairait
Hi There,
If you do not have APIC EM and PI integrated, this job is expected to fail.
they are system jobs and cannot be altered.
you can try to login as root user and try to pause it.
thanks,
Gautami
Thank for your response.
Actually, we do have APIC-EM and PI integrated.
The jobs created nowadays, are working correctly.
The problem is about old jobs, who were launched two years old and failed at the time. They are still appearing in "failed" status.
I would like to clear those old jobs but so far, I was unable to do it.
I tried to pause/delete them using the the root account, but the issue is still there. I get the same error messages.
