Cisco Prime LMS 4.2.2 syslog filter syntax?
dfaught
I am running the software appliance version of Cisco Prime LMS 4.2.2.  I have a syslog Automated Action that sends out an email notification for any severity 0, 1, or 2 messages.  Recently I found out that when a Cisco 2960 crashes, it logs 35 messages that form a report, all at severity 1.  I want to get 1 email for this and not 35.  My first thought is to use a syslog filter to drop most of the messages except for 1.  It looks like the definition of a syslog filter has some regular expression capability that would help in this case, but I can't find a description of it anywhere.  What is the syntax of the regular expression capability of a syslog filter???
Thanks for any help.
Dave
AFROJ AHMAD
Hi Dave,
If your need is to get notification for only SEV 1 messages then you can create a filter for it and rest all you can Drop.
go to
Admin > Network > Notification and Action Settings > Syslog Message Filters.
Attached is screenshot for the same. you futher can specify the mnemonics and facility as well ,if you want otherwiese SEV is fine
hope this will help you.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
Thank you for your response, but what you described is not what I am looking for.  I only want to drop a particular set of severity 1 messages, not all of them.
