Cisco Prime LMS compared to NCS
rschwendeman
What is the difference between the 2.  Can NCS do the same as LMS, but with support for wireless.
8 Replies 8
Leo Laohoo
For now?  NCS supports wireless but the wired network is very basic and crude.  This is after all a "code version 1" so alot of features are not yet operational and a banquet of bugs.
In the future, WCS and LMS will be merged to form Prime NCS.
rschwendeman
Since I am primarily looking to manage switches, would Prime LMS be better compared to Prime NCS.  From what leolaohoo has posted support for wired is very bacic.
Thanks.
In that case yes.
Look, you are in a quandry.  Here's the low-down:  NCS is currently very, very crude in the wired side of things, however, Cisco WILL IMPROVE this shortfall and will be adding/activating more features as each new release is made public.
LMS is probably your "safe" bet, however, LMS will not have a long life.  We are expecting and anticipating the End-of-Sale of LMS as soon as they can get NCS to be at "par" with LMS.
So, unless you have a very, very good relationship with Cisco (and associated pre-sales engineer), you might be able to get something like a this:  You buy LMS and when NCS becomes fully functional/operational, you can upgrade to NCS at little or no value.
alhaddad1000
Good day everyone,
For me i am still confused , NCS is mainly designed for the wireless and it is very weak on the wired connection
On the other hand LMS is excellent on wired connection
But excellent is flexible word I cannot see any added advantage on LMS compare to other monitoring tools
Can anybody help
LMS VS NCS
LMS Vs other monitoring tools
LMS and NCS will be merged in the next release, most likely in the coming few months. So the "LMS VS NCS" issue will be moot.
"LMS Vs other monitoring tools" is a huge question. It really depends on what you have in your infrastructure and what you want to do with your network management system.
If you're multi-vendor, LMS falls short as it is 98% designed for all-Cisco systems. On the other hand, few (or no) competitors offer the breadth of solution for a Cisco LAN infrastructure that LMS does. Also, LMS will of course have access to internal development resources and systems that no other vendor will ever offer. If LMS has a bug or IOS has a bug, it's one vendor who needs to fix it - no finger-pointing.
Many people use Solarwinds, for example. To begin to approach LMS, one would need both Solarwinds NPM and NCM. Even then you would not have the topology service or workflow that LMS gives you. You would also not have CiscoView. Likewise HP OpenView NNM falls short. As does What's Up Gold. They all do their intended function well - they just don't have the breadth of services built-in for a Cisco shop.
If all you need is configuration file management / archiving, then sure stand up an open source RANCID installation. It might be a bit cruder and require more Linux admin skills but it's perfectly functional. You won't get any support and that's all it does, but it does it in a workable fashion.
If all you need is performance management, use Cacti.
If all you need is fault management, use Nagios.
If you need fault and performance and are multi-vendor, use NPM.
If you need it all wrapped together and are a Cisco shop, use LMS.
extremely helpful thanks a lot for the infromaiton, i shall do more search and post it here once i find anything special thanks for the reply.
