Cisco Prime NCS 1.3
Mayham
I am running Cisco Prime NCS 1.3 and I have two questions that I hope someone can help me out with.
Question 1). Is it possible to forward the Rogue Device Logs back to our SIEM server? If so how?
Question 2). How do I setup the Mail Server Configuration? The part I am stuck on the is the Primary SMTP server.  For the username and password don't know what username and password I should use. Should I use the account I am logged into NCS prime ?
Thanks for any help or input.
Weiss
Marvin Rhoads
Weiss,
Re your first question. Prime itself cannot forward syslogs messages it receives. You may need to setup your wireless controller to use a secondary syslog server as your SIEM server.
Re the second, username and password is optional and only used when your mail server does not allow unauthenticated users from relaying mail.
If it allows that, you can leave those fields blank.
If it does require authentication, you should have a service account created on the smtp server for use by Prime when sending outgoing mail.
