EEM - event timer cron problem
b.petronio
Level 6
Level 6
I have a eem script that verifies if SIM 1 is active in my Dual-Sim router.
The event is activated every 5 mints with a time cron "trigger" .
event manager applet Fallback
 event timer cron cron-entry "*/5 * * * *"
 action 0.1 cli command "enable"
 action 0.2 cli command "show cellular 0 security | inc Active SIM ="
 action 0.3 regexp "Active SIM = ([0-9])" "$_cli_result" match sim
 action 0.4 if $sim eq "1"
 action 0.5  cli command "show clock | append flash:cron_log.txt"
 action 0.6  cli command "cellular 0 gsm sim activate slot 0 "
 action 0.7 else
 action 0.8  syslog msg "Allready on SIM0"
This was working fine, but then it just started to work like i was 2 applets running at the same time.
Instead 5 to 5 mints, i have 5 to 5 twice...
Already delete and recreate the applet. reload de router, and nothing work 😞
Demo-SIBS#show event manager history events
No.  Job Id Proc Status   Time of Event            Event Type        Name
1    10     Actv success  Fri Apr17 17:15:59 2015  timer cron        applet: Fallback
2    11     Actv success  Fri Apr17 17:20:00 2015  timer cron        applet: Fallback
3    12     Actv success  Fri Apr17 17:20:59 2015  timer cron        applet: Fallback
4    13     Actv success  Fri Apr17 17:25:00 2015  timer cron        applet: Fallback
5    14     Actv success  Fri Apr17 17:25:59 2015  timer cron        applet: Fallback
6    15     Actv success  Fri Apr17 17:30:00 2015  timer cron        applet: Fallback
7    16     Actv success  Fri Apr17 17:30:59 2015  timer cron        applet: Fallback
8    17     Actv success  Fri Apr17 17:35:00 2015  timer cron        applet: Fallback
9    18     Actv success  Fri Apr17 17:35:59 2015  timer cron        applet: Fallback
10   19     Actv success  Fri Apr17 17:40:00 2015  timer cron        applet: Fallback
## Degub ##
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_event_type value:24
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_event_type_string value:timer cron
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_type value:cron
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_name value:{}
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_time value:3638278200.002
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_time_sec value:3638278200
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_time_msec value:2
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_remain value:0.000
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_remain_sec value:0
Apr 17 17:50:00: EEM: policy_dir xml builtin: name:_timer_remain_msec value:0
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_event_type value:24
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_event_type_string value:timer cron
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_type value:cron
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_name value:{}
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_time value:3638278259.999
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_time_sec value:3638278259
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_time_msec value:999
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_remain value:0.000
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_remain_sec value:0
Apr 17 17:51:00: EEM: policy_dir xml builtin: name:_timer_remain_msec value:0
EEM v4.00
Any ideas ?
Joe Clarke
Depending on the IOS version, this could be CSCum88606.  It's fixed in 15.4(2)T1 and higher.
Thank you Joseph,
Im on a 15.2(4)M6, so i suppose, we could have more images affected.
I'll upgrade to that 15.4(2)T1, and feedback you later.
Thanks in advance,
Bruno Petrónio
