Cisco Prime netflow from Catalyst C9300
alberx
Hello, I know that maybe this is an extrage question because EoL of Cisco Prime.
One of my clients is happy with Cisco Prime and wants to use it until last possible moment. He has actually a Campus network with Catalyst C9300 switches and wants to know if it is possible to export Netflow data from them to Cisco Prime.
User guide says it is possible from Catalyst 3000, 4000 and 6000 (https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10/user/guide/ciscoprimeinfrastructure_3_10_userguide/set_up_network_monitoring.html?bookSearch=true#task_1057670)
Did someone try with C9300?
Thanks.
@alberx
Netflow is similar to snmp. What changes from one switch to another is how you configure It but the device does not care to who you are sending the data.
As long as you add the IP address on " ip flow-export destination"
It Will send the data to that IP.
alberx
What you say is the most logical, understood.
Many thanks Flavio.
