Hi everyone,
I have two Cisco Prime Servers. It was running okay. Until primary switched to the secondary as operational.
Version: 3.9 (3.9.0.0.219)
Now I see this error:
Check Failback Readiness: Failed
SYSTEM - CHECK DISK IOPS = Test is successful
NETWORK - CHECK NETWORK INTERFACE BANDWIDTH = Test is successful
DATABASE - SYNC STATUS = Primary and secondary database are not synchronized
NETWORK - CHECK NETWORK BANDWIDTH SPEED = Test is successful
The issue referred to the document but not sure how to proceed.
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-central/200654-Procedure-to-Rebuild-Active-or-Standby-D.pdf
Please help!
Beacon
