Cisco Prime Reporting
Joris Deprouw
Level 5
Level 5
Hi Guys,
I have a customer who used different authentication types for wired end users on his switches.
Dot1x - single and multiauth and no authentication.
Is there any way we could create a report with Cisco Prime to give us an overview of the authentication setting on each port? It doesn't seems there's a default report which could do this.
Any ideas?
Joris
gaston.benitez
Level 3
Level 3
Hi Joris.
As far as I know.
Prime infrastructure only comes with the sets of predefined reports that you can find in the GUI. What you can do is to combine reports to obtain another that has information from the combined reports.
Here is the documentation for Prime Infrastructure 3.6 as an example.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-6/user/guide/bk_CiscoPrimeInfrastructure_3_6_0_UserGuide/bk_CiscoPrimeInfrastructure_3_6_0_UserGuide_chapter_010111.html
Please, don´t forguet to score this post if this is useful for you.
BR
